Chemicals on hand for new finish
For quantities we need to know how many gallons are in your pool.
What test kit will you be using?
Test Kits Compared
What is the pH, TA, and CH of your fill water?
What startup guide will you be following?
Every gallon of 10% liquid chlorine will give you 4.2 ppm of FC. You will use about 2 PPM of FC per day this time of year in NY. So you need about 20 gallons of 10% liquid chlorine for the first month.
6 pounds of dry stabilizer will give you the 30 ppm of CYA you need for the first month.
I would get 4 gallons of 31% muriatic acid to start with.
Those are the basic chemicals you should need.
How will you be chlorinating the pool after startup?
after startup i will be switching to a salt system.
