First off, I have a Salt Water Pool. But I didnt run the SWG last year since the pool only stayed open for 2 weeks after construction and winter closing. So safe to say salt level is zero or very little. I did balance the other chemicals (PH, etc) prior to closing.
Here's the question...
When opening, I will fill up the pool to the skimmer level and will test the water chemistry. (I do have the Taylor K-2006 kit
). I will test for PH, Alk, CYA and FC. My question is...do I balance those chemicals first prior to adding salt? Or do I add salt, and let the salt work itself through for 24 hrs and then test for PH, Alk, CYA, etc? NOt sure if order matters, or if I can just do it all at the same time.
thanks.
thanks.
