I've used the pool math and Ran tests today, my FC is 2.5ppm, pH 8.2, TA 450-500ppm, CC is 0, and hardness/calcium 800+, CYA is less than 30ppm.
I'm wanting to raise CYA a tad, and get FC to 5ppm, and the pH also needs addressed. Water looks great, super clear, no scaling, just high pH and TA. Pool math is calling for over 2 gal of muratic acid, it just seems like a bit much, never put that much in before. Also, what is the proper order to address the issues/add chemicals? Add acid then chlorine, add on the same night? Wait a day? Just not sure on what to do.
Mike
Mike
