This just a rant to unload.
Yesterday I re-plumbed my pump outlet since it was developing a leak. After a few hours cure time, I tested the system for leaks and noticed major cyclical cavitation at the pump. Dumbfounded, I searched everywhere for leaks at the equipment and found nothing. Thinking that I had not reseated the hayward cartridge filter top properly, I reseated it three times out of frustration. I then checked and/or replaced and re-lubed all my o-rings including every Jandy valve, but the problem remained. Fearing the worst and about to make an expensive phone call, I walked backed to the pool and heard a loud gurgling and sucking sound from one of the skimmers. The weir door was jammed shut causing the water to drop and sucking air.
I spent half the day yesterday troubleshooting my pool equipment and it all came down to something so monumentally stupid. So with that said, after un-jamming the door and adjusting it, everything is back to normal. Moral of the story, don't jump to conclusions, because 9 times out of 10 its something trivial that you had not even thought of as a possibility.
