I've got a jandy clear check valve that I think may be stuck closed. This is for the jets on my spa. The separate pump turns on but the check valve never opens allowing water to flow out to the spa. The other main filter pump works fine allowing water to circulate through the spa.
Can I open the check valve and test the flapper? It has I believe 8 screws on top, but worried about breaking a seal or damaging.
What other troubleshooting steps do I have?
As far as I can tell from my plumbing pictures when the pool was built the jets are a closed system with a bottom drain and several eyeballs for return.
Thoughts??
Thoughts??
