Per the image below there is a check valve and Jandy valve between the single suction line coming from pool and the pump. My understanding is that the check valve ensures that no water come through into the pump if the pump is not powered on and operating. Our equipment is in the garage a good 10 feet below water level so this protection is necessary. Like an idiot today, I went to clean out the pump strainer basket without first closing the Jandy valve -- water immediately began pouring out of the pump at high velocity until I closed the valve. Since the pump was off and power was off -- shouldn't the check valve have prevented the water from flowing into the pump from the suction line? Appreciated.
