Check Valve assistance please
jsygrls
276
Port Orange, Florida
I have a 2" check valve that's starting to leak back to the pool overnight. The valve is about 20 years old, I'll post a couple of photos. The Brand name looks to be Flow Control out of California.
Anyone familiar with this brand? Can a replacement be found?
Can it be rebuilt??
Or is it better to replace the unit and replumb a new one in, if so what brand is recommended?
Find a Flo Control Inc part number on it and you may be able to find it listed here...
See if you can loosen the unions on the check valve to open it. After many years the PVC may have welded itself together.
Reactions: jsygrls
What part number is on the part?
AJW, Herman and JamesW, thanks for the info and attachments. I tried using some chalk to highlight Manf #'s, without much luck , I'll attach the updated photos. I of course, cannot free the unions with a strap wrench, I'll need to borrow some larger channel locks and give them a go, I would like to have the replacement in hand when doing this of course. As you said AJW their probably welded on by now and i'm guessing will probably break/crack with force.
Hey, JamesW this link that you sent me is what i"ll probable have on hand and replumb the new one in. It describes this fitting as a IPS type fitting, will IPS work with my 2" sch. 40 pipe and couplers and glue together like schedule 40?
If you are going to end up gluing a new valve in I would use a Jandy Check Valve. They are more easily repairable and you will not be faced with the same problem getting the unions unfrozen for the next repair.
Reactions: jsygrls
Unions are nice because you can replace just the center part without replumbing.
You might be able to unscrew the nuts and pull out the center piece and just slip in the new part assuming the nuts are not damaged when getting them loose.
Jandy can be repaired with screws and replacing the top and flap.
Praher also makes check valves with unions.
Thanks for what you do James.
Reactions: JamesW
