- Dec 7, 2014
- 113
- Plaster
- Pentair Intellichlor IC-40
I have seen various people have issues with this and thought this might help.
I Bought a used screenlogic2 off Ebay.
It would appear that old firmware on these units does NOT allow for resetting the IP address to DHCP by pushing the button 3 times (or maybe that never works?)
You pretty much have to guess and check until you find the IP range that the protocol adapter was once on. My guess is this is what prompts people to sell/recycle these devices in the first place (ie: getting a new router with different default IP range).
I had to go through all common IP ranges on my router until I finally got the PA brick to report an IP address in the 10.0.1.X range.
Then I was able to upgrade to the newest firmware from a PC on the same subnet. Then I used Screenlogic Connect to change it back to DHCP.
Now it gets its IP automatically from the router but requires a power cycle or 3 button push to renew the IP.
