Recent test results on the same sample changed substantially after 6 hours. Chlorine levels dropped, FC 10 to 8, pH increased from 7.2 to 8.2. using drop test , 7.9 to 8.5 using a meter. While tests are normally run within a few minutes using the TFT test kit, when samples are taken to Pool store tests might be several hours after samples are taken. I have not seen any info on changes that might be expected.
