- May 19, 2016
- 129
- Vinyl
- Liquid Chlorine
I recall hearing early in my pool owning days before I found TFP that lowering your pH too fast could damage your vinyl liner.
I don’t recalling reading anything here on lower your pH in stages so thought I’d see if that is a myth or truth.
The reason I ask is I need to lower my pH from 8.4 to 7.6 and pool math says I will need 1 litre of acid. Can I just dump 1 litre of muriatic acid in the pool or should I do a 1/4 litre at a time over several hours?
thanks.
thanks.
