I'm just finishing up my SLAM, and the chlorine levels are still high. I know you're supposed to wait till after the slam to adjust various levels, such as the PH. But I just tested the calcium hardness anyway since I'm going away tomorrow, and got a level of 190. I'm being told by Poolmath to add 87 lbs of calcium chloride to reach the 450 target. Reading posts here, I see that the 450 target may be higher than desired.
So first, what is a good target for a gunite pool with a SWG?
Second, is that test result accurate, given the high chlorine levels (25)? I would have waited to test it, but those staying at my house will not be able to test later. And I don't want to leave it low for that long if it's more beneficial to have it higher.
Finally, if the test is accurate, is it OK to leave at 190 for a couple of weeks?
Thanks--
Thanks--
