CH question
jimim
3,575
NE/Pa
TA 70
CH 300
Salt3400
Temp79
Cya 60
Ph 7.7 to 8.0
csi -.24 to .05
I put the range cause it climbs in 48 hrs.
I haven’t touched my CH cause it keeps my csi in check. If bring my CH up to 350 then I’m even more on the positive side when my ph is 7.7 to the 8.0 rise.
is that ok? Any advice?
I don't see a problem. Your CSI range is well within the +/- 0.3 range. As the water warms up it's going to push it positive, but it'll still be in range for a long time. Same with CH. Unless you get a bunch of rain and have to drain off some water, evaporation and refill is going to raise CH which pushes CSI upwards.
