Dear TFP Braintrust,
I have read various threads pertaining to tile pools and CH levels, most recommend maintaining the same CH levels as those prescribed for plaster pools, in my specific case (SWCG) the allowable range would be 250ppm to 350ppm.
Our pool was constructed of steel reinforced concrete (pour in place 3500psi) and is covered in Vidrepur glass mosaic tile, the tile was set and grouted using 100% solids epoxy adhesive grout, so in effect there is no cementitious or plaster material in contact with the water. The pool was finished in 2012 and as such the materials have long since cured.
I would like to maintain the lowest CH level practicable without jeopardizing the pool's finish or water quality, our home draws water from a private well and is treated to <30 ppm CH, the water is also treated/filtered and free of metals. I have a full water analysis from our well (pre & post treatment), this is done annually by an accredited laboratory, however, in the interest of brevity, I will refrain from posting the full report, but I can answer most any question about both our well and our output water which meets city potable water standards (except for chlorine levels, which are 0.0, we use UV sterilization).
Our pool is described in my signature line, but I will add a few additional details in the event they are relevant to any advice one of the forums chemistry gurus might offer. My apologies if I am omitting something important, please ask , and I will try to answer any questions accurately.
Our spa has jets (12) with forced a air blower. (I believe foaming can be a consideration with low CH levels)
Pool Water Chemistry (TF-100)
FC - 3.5
CC - 0.0
pH - 7.4
TA - 90
CH - 200
CYA - 40
Average temperature 91F (Maintained year-round with heat pump)
Salt 3300
We are undergoing major back yard maintenance and some renovations, while the pool is not being modified in any significant way (new return fittings, spa jets, floor drain covers and skimmer parts is about it) we did drain the pool, so a fresh fill is on the horizon. I intend to implement the water chemistry values recommended here on TFP, but would prefer to leve the CH as low as practicable, I would rather avoid having to blend in raw well water or remineralize the pool water to increase CH if at all possible, or at least keep this to a minimum.
So, what say the experts, can I maintain a lower CH level in my situation, or is 250 as low as I can go?
Thank you in advance for any advice!
Best regards
FC - 3.5
CC - 0.0
pH - 7.4
TA - 90
CH - 200
CYA - 40
Salt 3300
Best regards
