Hi everyone.
I am now the owner of an 18x38 inground concrete pool that I've gotten back up and running after 5 years of just sitting, uncovered.
The best info on have on age is at least from 1978 as it shows up on my septic drawing. It was originally plastered but then has been painted over a few times. This spring I installed 4 new 2" return lines, installed new skimmer with 2" suction as well. There were multiple cracks that had to be repaired which have all been take care of. Due to timing and incredible back up of pool plasterers in my area, I chose to blast off as much of the old paint and then repaint this season. This allowed me to at least use the pool this year and also to verify that all of my repair work will hold up.....so far so good. I've been using the TFP method for the last few years with my vinyl pool so am pretty well versed in the process.
My question is with CH. Does it matter as much with a painted pool as the concrete is not exposed? It is currently sitting pretty low and I'm wondering if I should get the levels up to the suggested amounts. My TA is also high at the moment.
Current readings:
CYA - 40
FC - 7
CC - 0
PH - 7.4
CH - 110
TA - 220
Appreciate any input.
Current readings:
CYA - 40
FC - 7
CC - 0
PH - 7.4
CH - 110
TA - 220
