D dielseman Well-known member Jul 1, 2017 300 GA Pool Size 8500 Surface Plaster Chlorine Salt Water Generator Apr 12, 2025 Add bookmark #1 Hi all, the CH is at 220. Trouble free suggest maintaining 250+. The chlorox bag advises 175-225. What should I do? Thanks
ajw22 TFP Expert Gold Supporter Silver Supporter Bronze Supporter TFP Guide Jul 21, 2013 65,250 Northern NJ Pool Size 35000 Surface Plaster Chlorine Salt Water Generator SWG Type Pentair Intellichlor IC-60 Apr 12, 2025 Add bookmark #2 What is the CH of your fill water? 220 is close enough to be ok. If you have very low fill water you might want to raise CH a bit. If your fill water CH is 200+ then you can be ok.
D dielseman Well-known member Jul 1, 2017 300 GA Pool Size 8500 Surface Plaster Chlorine Salt Water Generator Apr 12, 2025 Add bookmark #3 ajw22 said: What is the CH of your fill water? 220 is close enough to be ok. If you have very low fill water you might want to raise CH a bit. If your fill water CH is 200+ then you can be ok. Click to expand... Are you referring to the water that goes into the pool? I’m not sure. How do I test that? Just pour some water from hose bib into a cup and test?
ajw22 TFP Expert Gold Supporter Silver Supporter Bronze Supporter TFP Guide Jul 21, 2013 65,250 Northern NJ Pool Size 35000 Surface Plaster Chlorine Salt Water Generator SWG Type Pentair Intellichlor IC-60 Apr 12, 2025 Add bookmark #4 dielseman said: Are you referring to the water that goes into the pool? I’m not sure. How do I test that? Just pour some water from hose bib into a cup and test? Click to expand... Yes You should know the pH, TA, and CH of your pool fill water.
D dielseman Well-known member Jul 1, 2017 300 GA Pool Size 8500 Surface Plaster Chlorine Salt Water Generator Apr 12, 2025 Add bookmark #5 ajw22 said: Yes You should know the pH, TA, and CH of your pool fill water. Click to expand... Cool. I was not aware. Thanks for letting me know. Makes sense.
ajw22 TFP Expert Gold Supporter Silver Supporter Bronze Supporter TFP Guide Jul 21, 2013 65,250 Northern NJ Pool Size 35000 Surface Plaster Chlorine Salt Water Generator SWG Type Pentair Intellichlor IC-60 Apr 12, 2025 Add bookmark #6 dielseman said: Cool. I was not aware. Thanks for letting me know. Makes sense. Click to expand... Really, it is another chemical or chemicals being added to your pool.
