Just installed this motor on what used to be a single speed whisperflo pump. It works fine with builtin schedule b but when i set the dip switches for communication with The Pentair panel pump is not turning on. I am using a Cat6 ethernet cable and i have run it through the same conduit as the power wires. Could that be causing problems. I certainly haven’t figured out how to set a variety of speeds but selected VS in the intelliflo pump menu and set a single speed for now. But pump will not turn on. Any tips?
