Hi:
I have a 220V breaker at a main panel feeding 4 other breakers in a sub panel going to the pool equipment. The other day I noticed my pool was not running and checked the the other equipment, i.e. the cleaner, were running., which they are When I looked at the main breaker, the 220 breaker was tripped. If I reset it, and press F (for filter pump) at the Pentair Intellitouch panel, I hear a thud and the breaker is tripped. The breakers in the sub panel are not tripped.
I can spin the motor by hand so it's not jammed. I replaced the start capacitor, same thing. I am thinking it's either the relay in the Pentair panel (this happened once before when i replaced a motor) or the motor.
I also have an original Whisperflo motor for a twaterfall feature (not working - jammed). I was was thinking would it be feasible to switch the relays to see if that's the issue?
I have both a new relay and motor on order.
Any other diagnostics I can do, such as with a meter?
Thanks
Jose
Proud owner of a lovely green pool.
Thanks
Jose
