Moved from here.
Hi,
I'm planning on doing the same: glue back disintegrating bands on the filter cartridge. I have two questions:
Balint
Hi,
- Can I use simple hot glue if my pool also has a spa? The water gets pretty hot, up to ~104 F in the spa. Will hot glue hold up at those temperatures? My worst case scenario is that it softens, breaks loose, and clogs the spa jets.
- Some bands are missing or just too disintegrated. I initially thought of using long zip ties to replace the missing bands, but I realize that if those break loose and travel in the pipes, or get stuck in the furnace, I'm in for sone big pain. Do you have a recommendation?
Balint
