Hello everyone!
hope I can get some insight. To start, my numbers from the Taylor kit:
pH 7.4
FC 8ppm (first time below 12ppm in months)
CYA 50 (up until a week ago it hovered at 35-40)
TA 60
CA hardness 190
i SLAMMED the pool at the end of June and was able to successfully conclude it 3 weeks later - OCLT passed several nights in a Row, water was clear, and CC chlorine was less than .5 several nights in a row.
However, I've always had this feeling that the algae wasn't fully gone. Seems if it drifted below 15ppm, some indication of algae reared, often clouds on the wall when I brushed. so since end of June FC has been kept up over 12 ppm. Most of that even above 16.
Ive been vindicated because my green swamp monster is returning, confirming my suspicions.. I'm hoping you can explain why I'm having this problem. Here's why I don't understand:
1) CYA has never been over 50, so at most my target maintenance FC should be 8ppm. When I finished SLAMMING my CYA was 35. 50 CYA has happened just over the last couple weeks. Mini blooms have happened with CYA 40 and FC 18-20.
2) given my CYA levels, I've been above shock level for months.
So so I ask you, why am I having an algae blooms ABOVE shock level?
To be clear, current FC levels was allowed to drift below 12 only over the last couple days to allow for pH measurements before I could restart full SLAM procedure, which happened tonight. SWAMP STARTED BEFORE I LET IT DRIFT DOWN. Drift down was a result of the beginnings of the monster.
pH 7.4
TA 60
CA hardness 190
