- May 19, 2018
- 9
- Autopilot Digital Nano+ PPC2
I could write a book about all I've been through with the pool this spring/early summer, but will try to keep this succinct.
I've typically needed to SLAM once a season (this is my sixth season with a pool) and have usually been able to get a hold of any issue really quickly since I test daily and notice right away if something is happening. Historically, I've only needed two-three days to get OCLT to pass. Not so much this time and I have no idea why and am getting really discouraged. The pool looks amazing but something is absolutely demolishing chlorine at an alarming rate. Currently adding upwards of 2-3 gallons of 12.5% chlorine per day just to try to stay at SLAM level of 16 FC... I've been at this for over a week now, and it is not slowing down at all (losing 12+ FC PER DAY).
After reading through many other posts I've taken apart pool lights as best I can, have no ladders or main drain to clean, so suspect it may be something in the skimmer (but perhaps this is a red herring so please provide other suggestions if you have any).
Why I fear it is the skimmer and have no idea what to do:
Current readings (pool is sparkling, no one would ever guess something isn't right - attached picture has pump on high and was dark and windy but you can clearly see the bottom of the deep-end from ~60 feet away):
Cheers,
Steve
(1) In the attached pictures you will see some "scuzz" in the skimmer that is greasy/oily - I convinced myself that it was sunscreen but am starting to second guess that position. Thoughts? It definitely seems related to pool usage as there is more after people use the pool and hardly any if the pool is not used. Regardless I've been brushing/wiping it down as often as I can.
(2) If this is some sort of algae/organic you may notice in the picture the skimmers have cracked over the years (probably due to winter freezing/concrete settling?) - how will I EVER get inside those cracks to properly brush/clean them? If this is the problem, is this why it won't "go away"?
(3) The installer put too much caulking around the skimmer mouth plate so it is also impossible to fully clean (the caulk also has some black spots above the water line in it - is that algae?).
FC 16.5
CC 0.5
pH 7.6
TA 100
CH 260
CYA 40 (between 30 and 40, so round up)
Salt 3400
Temp 86
Any suggestions/help would be greatly (greatly!) appreciated.Cheers,
Steve
