Cant match holes in fiberglass steps during liner replacement
Pchase
May 26, 2016
53
Amarillo, Texas
Replacing the pool liner right now. Several of the screws holding the sealing strip around the stairs in place were stripped and had to be grinded off.
I have all new gasket material and strips. The issue is I can't match up the holes in the stairs because there are screw remnants in several of them.
Will it leak if new holes are drilled and the gasket over that? Can the holes be filled and then re-drilled in new spots? I also could try to line up the holes that remain and only drill new holes near the ones with screw remnants in them.
