Hey guys,
My first post in this forum and I'd like to appreciate any further comments/suggestions in advance.
I have a concrete pool with almost one year old (SWG). The concrete is not in direct contact with the water, it has a impermeable "skin" all around that is used as a finish and cover of the sides and bottom. I didn't know anything about pools but now I think that I'm pretty aware of many things that could unbalance my pool but not this one. I fill my pool with a well water, that may have a significant amount of copper in it since the by the two times I put salt into it then it became green (right after a few minutes) for a couple of days until it got back to its beautiful blue. I believe its copper since I got some yellow stains around the water-line, that I was able to remove.
During the winter, I didn't get much attention to it, I admit. I thought it was pretty easy to handle (just check the machines, ensure water was clean, etc...) but then came the spring, small little pieces of algae started to show and I started to study how to get rid of those issues. I installed an acid pump, that allowed me to be more sure of the pH level.
My pH was around 8.2 (or a little more), because the natural ceiling is around 8.4/8.5 and hadn't had any maintenance from my side until that point.
I bought several amounts of ph minus (25kgs each) and started to let the pump do its work. It took a long, long time to drop it until 7.2, and to drop the alkalinity from 240 ppm to 70/80 ppm. To speed things up, I did it manually pouring huge ammounts at once around the pool and being previously diluted.
I'm very concern with this because I just have the return jets (15/20 cms below the water line pointing horizontally) and somehow my pH rises around 0.1 each day (if the acid pump is off). I think its too much when the jets don't even create bubbles, just a slight turbulence. I've tried to keep it around 7.2, 7.4, 7.6 and now 7.8, but its hard to keep it in between any of those values (harder on the low end) without wasting and wasting bottles of acid (around 25 kgs in 1 week, if not less).
Since I live in Portugal, we don't have your usual pool stores. Even the strips have much less info that yours (only TA, pH and FC). Things got worse when I started adding chlorine tablets to a dispenser when I was one week away and had no salt to relay on the SWG, and when I added granular chlorine to fight the greenish tone of my pool when I put the salt back in it a week later.
Since then, the pH is around 7.8 (wasting almost a bottle every three days).
May it be due to high calcium hardness? I don't know its value, but I guess the chlorine tablets and granular might have messed it up. I dropped huge amounts of acid and it seems to have no result lowering the ph now...it's weird but that's the truth. It just "maintains" it at 7.8.
This has been giving me headaches for months, I just wanted to understand what may be happening so I can fix it accordingly. I can't afford to waste that much of acid (and money) that fast.
TA: 70
pH: 7.8 (and rising)
FC: 2.8
65K liters / 17.2K gallons concrete pool with impermeable "skin"
SWG + Acid pump + Sand filter
Filled and refilled with well water (around 2000L every 3 weeks or so on spring/summer season, no need to refill on autumn or winter)
All equipments run the same number of hours as the water pump (8)
Cheers!
TA: 70
FC: 2.8
Cheers!
