- Nov 12, 2020
- 28
- Plaster
- Pentair Intellichlor IC-40
Hi all. I am in a bit of a pinch. ComEd shut off our power to do some line work for about an hour. When it came back on I immediately checked the temp of our spa since it is open in the winter and it had dropped about 20 degrees. I went to the equipment pad and the breakers had tripped for the pumps and filter. I flipped them back and they are not turning on. The primary pump is displaying an alert that the power was out. I am not sure what to do as the power is back on to the pad. The pump for the spa is working fine so water is cycling in freeze protect. Unfortunately it's getting colder without the heater.
