cant get pool clear
zwats
0
Sep 8, 2018
33
ky
went out of town for a bit and when i got back chlorine was at 0 and i couldnt tell if i had just dirt or green spots (new dark liner so hard to tell). i vacuumed/brushed and put in liquid chlorine and its been cloudy ever since. it was most cloudy when chlorine was at around 6, as chlorine went down it cleared up a little but still cloudy
my current levels are
TA-74
ph-7.6
fc-4
cc-.5
cya-65
ch-95
poolmath says to add 9 jugs. slam process says to add 3-4 times a day. should i add all 9 jugs to start
Yes, if the chlorine is 10-12% then each jug will give you about 3PPM. 9 jugs will give you the 27 PPM SLAM level FC.
Test 3-4 times a day. Add whatever chlorine is needed to bring FC back uo to 28 ppm.
water seems like it got worse. is that normal after adding that much chlorine?
