I have a fiberglass pool which I've been slamming for about 8 days now. I've also been vacuuming the pool at least once a day. I've been keeping the FC above 11 very consistently. My water looks clear. I been able to pass the overnight test where the FC doesn't go down more then 1ppm. However, I am unable to get the CC down to less then 1. A few days I tried to increase the FC to 15 or more, but still I am getting CC at 1. Here are my numbers:
FC: keeping above 11
CC: 1.0
Alkalinity: 80
PH: 7.5
CYA: 20
CH: 175
How long should it take to get it to come down to .5ppm or less? Should I attempt to keep FC even higher?
I am also seeing the PH rising every day about .5ppm. Have had to add Muriatic Acid to keep it in check. And I have unusual staining which doesn't clear up (posted a separate thread on that) with slamming and did not respond to a puck test.
CC: 1.0
Alkalinity: 80
PH: 7.5
CYA: 20
CH: 175
