I'm opening my pool, and tried to run my DE filter. I let it fill with water until it started coming out of the release valve, and closed the valve. Water is still coming out of the valve, even though it is completely "closed." When I shut off the pump, I can hear air coming out. Okay, I thought, I'll just run the pump in recirc mode until I figure this out. When I switched the pump to recirc, water started coming out of the pipe where waste and backwash leaves the system. It appears something isn't closed up like it should be, but I can't figure out where. Or could it be something else? Maybe I need a new release valve? Any ideas? Thanks!! Here are a couple of pictures of what I'm describing:
Kelley
Kelley
