I’m doing my best with the patience lol. Is the cloudiness due to the fine particles of algae floating around in the pool? If that is the case then what will get rid of those tiny particles that aren’t being caught in the filter?
This is baking soda, and you didn't need it. Now your TA is high. However...no need to worry about it or to ANYTHING to reduce TA. Your pH will rise over time, reduce it with muriatic acid. As you do this, your TA will come down.Balance pak 100 to raise alkalinity
This is sodium bisulphate. Dry acid. Don't use it in the pool, it adds sulfates. Use muriatic acid to lower pHLo’n slo to lower ph
This is CalHypo. It chlorinates and adds Calcium to the pool.Burn out pool shock
This is a pool store potion. You really don't need to clean a sand filter unless it is gummed up (assuming that is what you have). If it is gummed up because of pool store potions, you likely need to deep clean, or replace sand. Given the chemicals you listed, they would not gum up a filter.Filter brite to clean filter
Oooof. No idea how much floc got to filter.You’re not going to like this one- biogaurd power floc. On the recommendation of the pool store I was going to. I let it sit for 24 hours with no change and vacuumed to waste slowly and carefully and had instant regret when doing it.
