Thank you jblizzle, for your understanding response. I am a newbie at this. This is my first year to RE-open. I first opened last summer and messed up because I failed to put in enough salt and I didn't run my SWG long enough to keep the FC level up. I ended up with a GREEN mess. That's when I found this forum and was put on the right track. You guys are a tremendous help. My problem is understanding the Pool Calculator so please bear with me on that part. I just want to do things right the first time this year as I re-open my pool. Here is where I stand right now:
My water level is just below my skimmer outake. I am still adding water to fill it.
My pump is hooked up but not running yet.
Water is green and yucky. (I did not totally drain from last summer)
Here is what I am understanding that I need to do from here:
Once the pool is full, get the leaves out and turn on the pump to run for 24 hours
Test the water see what the numbers are
Here's where I get stuck! Go to the pool calculator and figure how much bleach to use to shock it. :?
I don't mean to be a bother, but you guys always give great advice so that's why I am asking for help. I learn by doing! Not so much by reading! Sorry....
