Hi there, I’m doing some pool upgrades. I recently removed an aging single speed Hayward 1.5hp super pump, and added a new 3hp VS pump. Also changing from an aging Pentair TA60D sand filter to a Waterway 425 cartridge filter. The existing plumbing is all 1 1/2 inch, I have a skimmer suction line and drain suction line. And 1 1/2 inch return line. (The return line runs above ground due to prior owner repairs, so a switch to 2 inch would be easy). No other frills, pumps, lights, fountains, etc.
I’m wondering if I can feasibly, without creating plumbing or flow issues, adapt the two 1 1/2 suction lines into a single 2 inch line into the pump and thru the new filter, and a new 2 inch return line to the pool?
Thanks for offered advice…
G
G
