I am in the midst of building my 1st pool, in Honduras.
I will be installing the pump, filter & SWG in a pump house I have, that currently houses my 1 hp water pressure pump.
I am a novice when it comes to electricity, so want to know if I can place the pool pump on the same circuit as the pressure pump. Both will be 110v, 1HP. I am currently running 14 gauge cable from a 30 amp breaker, to a sub panel in the pump house.
Or should the pumps be on separate breaker circuits?
Finally, would I be better running 220V to both pumps (they are both capable of 110 or 220)
Thanks in advance for any advice you can provide!
