Can peromonosulphate drastically reduce ph? I ask this as my spa ph dropped off the scale and chloring readings were at zero despite have ing been added daily.
MPS is net-acidic when added to the water (lowers pH). Bleach will initially raise pH because it contains excess lye from the manufacturing process but that pH rise should be lowered over time as bromine chemical reactions are acidic. Your tablets are also acidic as well which is why you pH is going down.
If you plan to use tablets then you need to monitor pH and TA closely and add back alkalinity (using baking soda) as the TA decreases. Baking soda will also slowly raise pH as carbon dioxide outgases from the tub.
