- Nov 28, 2020
- 269
- Plaster
- CircuPool RJ-45 Plus
I have a curious issue with my pH and muriatic acid. While I was out of town for two weeks my wife was handing the pool chemistry for me (her first time). She was using the Taylor test kit and the pool math app. At one point the pH was 8.0, and when she would add muriatic acid she would get the same result the next day.
When I got home yesterday I performed the chemistry tests, pH was 8.0, and the acid demand tests indicated 4 drops to lower the pH to 7.6. I added the correct amount of muriatic acid, 1 qt. 24 oz., from a case I had bought right before I left town (the same one my wife had been using).
Later tests that evening and again this morning, showed zero change in my pH level. The test acid demand test was again showing 4 drops to reach 7.6 pH.
I will add she left the acid outside where it was exposed to afternoon sun, but also the glue from the jug seal was black and bits of it were crumbling into the measuring cup. I also know my local pool store's warehouse is not climate controlled and it gets very hot from the New Orleans summer. Is it possible the sunlight exposure or the warehouse storage could have neutralized the acid? Adding a few photos from my phone after I post this.
Thanks/g
Thanks/g
