Can M500 clear Paramount SDX drain covers?
I'm sorry I can't say for sure, but they make special covers to go over normal ones like that which lower the profile, and allow Bots to travel over them. They will be pretty large in diameter to lessen the projection, but way cheaper than a new Bot. I don't know of any covers the 500s get stuck on, but I could have missed that. Usually you don't hear much about them getting stuck on drains. I think partly perhaps too because they have more ability to get off with dual brushes and different maneuvering capabilities. Some have attributed this to the bottom brush, but I've just not seen mine get stuck.
Thank you. I have looked several ramps as well as attachments that keep the robot from going onto it in the first place, but none are compatible with the SDX due to its large diameter and design. Not thrilled about draining the pool and replacing them (if I can find ones with the same bolt pattern?) to accomodate the robot when it is supposed to make life easier...honestly I would rather replace with a better model or just go back to my suction side cleaner.
M500 came today and I set it up. First thing I did was go into manual mode and drive over the drain cover; made it with no problems. The Active 30 could not do that. As a bonus, it turns normally as well, whereas the Active 30 tries and often fails to turn using water jets.
