Re: Can I run Cartridge Filter with the 4 cartridges removed
Also:
:idea: With the "Spillover" closed completely; no bubbles anywhere and the
pump water is different. SEEMS about 1-2 inches below lid with "some" small
bubbling. The "churning" is evident from I believe the force, but not "bubbly-churning"
When I first bleed the filter, ANYTIME, there is a NO WATER release..then solid water.
Unless the "pause" is normal, there is a lot of air entering. [It is all or nothing, no spurting]
MOST IMPORTANT TO ME RIGHT NOW [NOT INCLUDING THE HEATER...its coming]
I am convinced beyond a doubt that a blockage exists in the main drain. If the skimmer valve is
closed completely, the vortex starts. I have brushed dirt over the top of the main drain and the
various pop-ups blow the dirt other directions....no suction at all that I can see.
So....that is where I am
Also:
