I just did the full line of tests as I usually do this time of year to "close" my pool. I say that in quotes, because I don't actually close since it doesn't get cold enough here in California, it's my end-of-season routine. I'm seeing TA of 50, and I've never seen it get that low before. My pH usually rises all the time, but I haven't added acid in quite some time and am sitting at 7.9. My sense is that I'm good to leave it as is, as long as the pool seems happy, and it does. Any reason to bring the TA up?
This are my results before adding anything:
FC 2.5
TC 0
pH 7.9
TA 50
CH 550
CYA 30
Temp 64
CSI 0.07
My plan is just to run about ten 3" trichlor tabs two at a time in a floater over the month or so to bring the CYA back up to 50, and that should keep my pH and FC pretty well in hand, then go back to liquid chlorine, which I add very little of in the winter months. Water is getting cold enough now there isn't much concern of algae, which I've never had an issue with.
FC 2.5
TC 0
pH 7.9
TA 50
CH 550
CYA 30
Temp 64
CSI 0.07
