Testing 5 minutes or so after all additions is fine - things get dispersed quickly in a tub.
When manually chlorinating I usually raise fc to around 10ppm after a soak then the tub is around the 6ppm range the following day before the next soak. This is enough in my tub to get me through the next use of 2 people/30 minutes then I do it again.
My tub is small (200 gal) so my bather load is twice as large as the average 400 gal tub. You may not need to go as high to ensure you never fall below min for your cya.
Your frequent testing (before & after use) & during standby times will help guide you.
With my swcg I usually only dose to around 6ppm after normal bather loads as the cell comes on multiple times per day & keeps the fc quite steady.
If the kiddos get in alot (they tend to go back & forth from pool to tub in the shoulder seasons)
or there’s a party
or we long soak I add fc or turn the swcg on after each 30 minutes of use and usually raise to slam level after to help oxidize all the things. Guests often have fabric softener in their suits & lotion on their skin, teen girls use products in their hair & such so those things can chew through some fc.
My tub claims it’s a 5 person but 2 adults is comfortable. However I have had 5 kids/teens in there and that drops fc quickly!
Ps - when you run out of the leisure time stuff get some ahhsome - it may be ahhsomely gross
but in a satisfying way!
