Calculating pH from number of drops of acid demand reagent?
Is that what they are using?
I assume so.
The R-0015 acid demand drops use the midget comparator which is roughly 4.5mL sample size. Since the chart is the same no matter which test reagent you use, I’d assume the R-0015 is one tenth (roughly) the strength of the R-0005.
So, using the 0015 acid demand test with the large comparator could improve the resolution of the method, but needed an adjustment of the table. With a factor of 10, that wouldn't be too hard.
We need to know for sure.
If they are using a smaller volume, then that will throw off the results.
I guess that could be relatively easily checked, at least with the precision required here. Just check if 10 drops of 0015 in a 44ml sample result in the same pH change as 1 drop of 0005. Or 20 or 30 drops of 0014 with 2 or 3 drops of 0005.
Either with a pH-meter or by having two 44ml samples with R-0004 indicator next two each other (use the comparator to measure the right quantity and pour it into another tube or even just a glass like a 100ml wine tasting glass - ideally use two identical tubes/glasses). That allows direct comparison of the colour changes.
I guess, for the method to actually get used by non-nerds it shouldn't involve diluting reagents. And nerds like us will probably just buy a pH-meter and move on to the fridge with the cold beverages.
