- May 23, 2015
- 25,692
- Plaster
- Pentair Intellichlor IC-60
So, just to add a little detail, I went ahead and measured all my calibrating solutions (4,7, & 10) after having calibrated last week and 4 & 7 were only off by 0.03 pH units and the 10 standard was reading 9.88. Those are within the accuracy of the unit as Apera guarantees a +/- 0.10 variation when a 3-point calibration is used. I’m not surprised at the drift at the high pH range as pH probes are notoriously difficult to get accurate measurements at high pH. Even with laboratory designed probes, you need to do special calibrations if you want a pH meter to perform accurate measurements above a pH of 10. And if you truly needed accurate pH measures in the high range, the standard Ag/AgCl electrode is not the best choice.
