A. Not sure what you mean here.mas985 said:Does that redirect water through spa returns or jets?
A. Yes
How many spa jets/returns and what are the sizes?
A. Six jets. Not sure on size. The returns are 2.5 and the suction is 3.
How long are the runs to the spa and what is the pipe diameter?
A. Spa is about 70 - 80 Feet from the pump. Pipe is 2.5 inches
How does the filter pressure change when going from pool to spa return mode at higher RPM?
A. Need to check that
Switch between pool and spa mode with the return valve only so that only the return side plumbing is changed
(i.e. spillover mode).
