Just received my new TF-100 refills! Test results are:
FC 15.5
CC .5
PH 7.4
CH 625
TA 50
CYA 20
BOR 50
Chlorine is high because I dumped in 3g of 12.5% before brushing. Tested last evening and had those results. Test again this morning and FC 16.5, CC 0. Not sure how it rose as the puck feeder was off (using up some pucks since CYA is so low). Anywho, my question is about the high Calcium. I'm not really sure what has caused it as I haven't added any in a while - and probably not near enough to get it that high.
Should I have any concerns with a CH of 625? CSI with those numbers is acceptable ( -0.12 ).
Thank you.
FC 15.5
CC .5
PH 7.4
CH 625
TA 50
CYA 20
BOR 50
Thank you.
