Hi!
So our new WetEdge Primera Stone Spa had some initial issues and they came to repolish it with these diamond blades. It got repolished and I started testing water chemistry daily and added PH since it rose a bit quicker than usual. Below the results that haven't changed much:
PH 7.6
Calcium: 275
TA: 70
Salt: 3000
CH: 4.5
CC: less than 0.5
CYA: approx 40-50
Temp: 80
LSI: -0.07
What has changed is that the calcium hardness test now all of a sudden starts purple.
In addition to that the brand new polished spa is getting rough after 2-3 days, i can then use a fine 180p sand paper and it gets perfectly smooth again with just one wipe without a lot of pressure. So I assume it is some form of scale that is growing on the surface ... but based on the LSI scaling should not be possible?
I read that a purple calcium test could indicate metals. Is it possible that the polishing machine somehow increased the metals in the water and this is now causing scaling issues?
PS: i should add that starting with the 5 drops of R0012 starts the test in red again.
PH 7.6
Calcium: 275
TA: 70
Salt: 3000
CH: 4.5
CC: less than 0.5
CYA: approx 40-50
Temp: 80
LSI: -0.07
