I have a stone block wall with stone scuppers. When running the scuppers a lot I get scale on the stones that shows up a day or two after I stop scuppers. I keep my ph around 7.4-7.8.
ph=7.4-7.8
Calcium= 600 (tap water is probably 400, really high here in north Texas)
TA = 90-100 (I haven't been tracking this regularly
CA= 50
One note is that when the scuppers are running the pool of water inside the scupper seeps through the mortar and into the adjacent stone.
I don't know if water seeping through the stone wall from the scupper is pulling calcium to the surface of the stone, or is the splashing on the stone is causing the calcium to leach out of the water onto the stone.
Is it inevitable with my high Calcium?
What is the best way to remove the scale on the stone and it also runs down onto the waterline tile?
ph=7.4-7.8
CA= 50
