- Jul 21, 2013
- 54,521
- Plaster
- Pentair Intellichlor IC-60
So again my question is what should I do? I have had multiple pool companies come out and they either don't return calls after or say its not something they want to deal with.
No pool company wants to touch it becasue they cannot guarantee they will fix the problem. And once they touch it they own the problem.
- Should i just clean it up and replace the tiles that are loose and then seal it? Also is a sealer really going to do anything since it has water running over it for an hour a day?
There is no "sealer" that will permanently keep water out.
- Should I replace the tiles and do epoxy grout?
Yes, this is your best solution.
My concern there is that if both sides aren't waterproofed, is it going to ultimately cause the tile to pop off.
You will need to repair the grout every year and tiles every 5-10 years. Just part of your pool maintenance.
- Any solution for how to stop water from penetrating the area between the pebbletec and tile?
The buildup should be Pebbletec, grout, and tile with no place for water to get in if the grout is properly maintained.
Post a pic of that area.
