Calcium on decking?
300winmag
220
Dallas, TX
Resealed our decking earlier this year with the same sealer used last year; pure acrylic. I added some glass beads this year to improve traction, and its worked out very well!
Over the last few weeks we've been getting what i think are calcium deposits on the decking. Seems to be worst in the areas that our dog drips off. He's a 100# golden, so he seems to drip gallons at a time.
Anyway, curious how to confirm what it is, then how to remove it, and then how to prevent it!
I'll get a pic up in a few.
Thanks!
Try spraying some diluted MA on it, maybe 5:1 water:MA. If it fizzles or is easily removed, then it's calcium.
A spot test in an inconspicuous area would be best. I don't think a 5:1 dilution will cause any damage but better to be safe. You could always tape off a small test area and sponge the excess off right away to see if it impacts the stain.
If it is calcium, then it should fizz right away or be cleared up very quickly. Results should be immediate. If it's something else then the MA will have no impact.
There are efflorescence cleaners available that area design to remove calcium without damaging underlying surfaces. But better to test first to see what you're dealing with.
