Thank you for your replies and for the links. We used someone who is a pool builder (recommended by a friend) who then subcontracted out the demolition and plaster job to another company. We didn't realize he was going to do this until it was too late. Also, unfortunately, we had an old crack in our pool and so the builder would not warranty the plaster job and recommended we do just plaster instead of the quartz we wanted in case the crack came back. I'm not sure what recourse we have without a warranty.
This is his current analysis:
Originally very slow fill time, maybe water stopped during fill or bad water pressure. Prominent eggshell cracking on Baja, upper walls, and spa. Common with color plaster finishes with either extreme heat or slow fill time. This pool was shot when the weather was high 60's to low 70's. Most likely, bad water pressure or water stopped during the filling of the pool.
Current condition, whiting and calcium nodules growing due to high Calcium Hardness in water per chemistry report provided by customer. Pool has to be drained, acid washed, and light sanding to nodules. One pop-off on pool wall most likely due to a calcium nodule coming loose and taking plaster off as well, or someone tried to remove nodule causing plaster damage. This would have to be repaired while empty - (no guarantee for match). Salt is also too high which can cause increase in calcium hardness as well. Report states water was at 55 degrees when the report was done.
Pool should not be drained for about 10 days after all of the heavy rains have stopped. Draining too close to heavy rains can cause a pool to float as a worse case scenario.
And this is what he is offering:
Unfortunately, given the current conditions of the calcification, there is only the one way to attempt to remove that, and that's with acid. I have to trust that they wouldn't recommend it, if, it wasn't ok to do it. Acid Wash, sanding of the nodules, and the repair they would charge us $925.00. Unfortunately, the current conditions are a direct result of pool water chemistry and not the work that we provided. That said in light of everything with the footprint that was left, we would be willing to split this cost with you. Not figured in this cost is the water and chemical balance, you cover the water, and we will provide the initial start-up. Hope that helps.
I don't know what to do. Should I move on to another company to come do the repairs or just use him? In hindsight I never should have used the guy--lesson learned.
