Hi all, my calcium levels were off the charts high, so I drained my fiberglass pool about 60% and replaced it with water directly from a full house water softener. When doing a test of the home water (by itself) all levels are normal; the calcium is about 200. but after refilling the pool, the calcium level didn’t even seem to budge.
Other Numbers before draining were within normal ranges and had been normal all winter
Here are the numbers, after refill:
TCH/FCH- 1 (only using a tablet at that time, but will increase with liquid chlorine)
PH-7.7
ALK-90
CYA- 40
calcium appears to be almost 1000
So why is my pool still so calcium happy??
PH-7.7
ALK-90
CYA- 40
