Can any of you help me in regard to the "fading endpoint" issue with the TF-100 calcium hardness test? If I carefully follow the CH procedure, 8 drops of R-0012 gives me a “purplish blue” (my son called it “indigo”) color.9 drops starts to turn into a true blue, and it stabilizes at blue at 10 drops. Does a "purplish blue" or "indigo" color constitute a fading endpoint?
I have tried adding 5 drops of R-0012 first, as suggested for “fading endpoints.” If I then add 10 drops of R-0010 and then 3 drops of R-0011L, it turns pink. 3 more drops of R-0012 turns the solution purplish blue—perhaps a bit more blue than purple. Is this a fading endpoint as well?
I also tried diluting 50:50 with distilled water and adding 5 drops of R-0012 first. I then added 10 drops of R-0010, and then when I added 3 drops of R-0011L it turned blue immediately. This seems to agree with the fact that 10 drops of R-0012 gives a true blue (first paragraph of this note), and would seem to indicate a calcium hardness of 10 * 25 = 250 ppm.
I have also periodically had my water tested at pool stores, and have gotten results all over the map--from a low of 159 to a high of 280 ppm. During this same period I seem to be generating results with my TF-100 kit (aside from the "fading endpoint" issue) that are consistently in the range of 200 - 250 ppm.
Some of the variation with pool store results is probably related to different testers at Leslie Pool Stores using different amounts of carefulness in the testing procedure. However, during this time I have had two tests done at Anthony & Sylvan, and they use the LaMotte WaterLink Spin tester, which would seem to remove the human factor from the test results. A&S has generated results of 159 ppm and 178 ppm--both of which are low for a plaster pool, and this concerns me.
Are any of you familiar with the LaMotte WaterLink Spin tester, and the quality of results that it generates?
Thank you in advance to any of you who are able to provide some insight to my question.
Carl
Carl
