- May 3, 2014
- 58,475
- Fiberglass
- Pentair Intellichlor IC-40
Regeneration of the On the Go RV water softener is easy, but does take time.
First I unhook the outlet hose and hook up a hose to run to my sewer cleanout. Then take off the inlet hose and use an air hose to blow out the water. Then take the top off and dump the two boxes (about 3#) of salt into the vessel. Hook back up the inlet hose. Then run the water through the softener at the low rate as described in the instructions for about 30 minutes. Then flush at a high rate. Take the outlet hose off and hook back up to the autofill.
If there is any way to use a conventional softener, do it. My only issue was no place to send the effluent during regeneration. Or if you have an available softened water line (even inside the home) near the equipment pad, get that run to the autofill.
