Hi everyone. My pool has been in great shape since finding this place and firing pool guy and taking it over myself a few years ago. I live in Florida and the weather started getting very sunny and warm over the past 6 weeks. For the start of the season, I cleaned salt cell, filter and checked all levels, including the ones I don’t check too often because water so clear/clean, isn’t much of a need to as I’ve gotten to know my pool.
My current numbers are:
Free chlorine: 6 (and very stable over months)
Ph: 7.9
Alkalinity: 90
Cya: I don’t currently know the number because I need to reorder chemical but as stated above, chlorine is stable.
Salt: 3400
I’ve noticed with my pool, the ph stays in the higher normal range (7.8-8.0 ish) when my alkalinity is above 60. I’m able to keep it at 7.4-7.6 easier when alkalinity is 50-60. But I learned from you guys, that’s understandable and leave it alone and let it lower in its own in time. Which it tends to do in warmer months and stay 90-110 in cooler months. I adjust ph when it’s 8 or higher.
Calcium hardness is 750. And it’s always been higher in this pool. I assume it’s the water where I live. I believe I recall someone telling me that isn’t anything to worry about or do anything about, am I making that up? That’s my question.
I have a Pentair easy touch and intellichlor salt generator. Pool and spa with spa flowing over into pool.
I do notice this white small substance blow into hot tub once a week and I just use pool blaster to vacuum out. I don’t know if it’s related to the calcium. I do not have scale on tiles etc. I do get calcium build up that’s noticeable on the salt cell when I clean it every 3 months. It’s pretty thick but, I am able to get it clean with vinegar/water. I have the white sediment in the spa now, I’ll attach a a pic and maybe someone can help me figure out what it is.
Ph: 7.9
Alkalinity: 90
Salt: 3400
