I would recommend that. You have a water softener, so while you're at it, I'd get it right and then you shouldn't have to drain ever again.
600 should be manageable as long as you keep TA and pH low enough, but I reckon it would be a bit of a pain to keep the SWG cell from scaling. With Borates (to keep local pH within the SWG cell from rising too high), 600 could be OK, I think. Without Borates I'd go lower.
Play a bit around with PoolMath. I summer CSI should be ideally between -0.3 and 0, in winter it is OK if CSI goes lower (due to temperature)
